In the video its running at around 20-25 lbs. I use a portable air tank in the basement and the gauge is not terribly accurate. When I increase the pressure it accelerates smoothly until it hits about 45-50 lbs. Then it starts having an asthma attack and jumping all over the bench. Would this be the spring on the exhaust valve? Right now its just one out of my small DrawerO-Springs and Id rate it at medium to light. The other thing Ive been thinking about is the flywheels. Their just under 1 lb. each. Would lighter be better?
