I cut out a connecting rod and added a brass bushing in the piston end.
This is the way I cut off the caps on the main and rod bearings after the bolt holes are drilled.
Everything even fit and in line.
Next I will take it all apart and do some filing, some polishing, and make some cross beam supports with rubber feet.
I received the helical gears and the driven gear is big that's because of the 3 to 1 gear ratio.
I will have to do some special machining to make them fit and still get the flywheel on the shaft.
In order to get enough room for the driven cam gear and the flywheel to happily coexist on the crankshaft I milled a slot in the bearing support.
Here is a shot of the outrigger legs front and back with rubber feet attached.
I will be using a pair of flywheels I had made for a different engine but didn't use.
Note the stepped slot for the cam gear.
Big day today first I cut out some cam bearing supports.
Drilling, tapping, filing, adjusting, and polishing to get this.
I have 1/8" clearance at the flywheel with the taper lock bushing flush with the end of the crankshaft.
If you remember I said earlier that I had made this crankshaft much too long but I could cut it off later if needed.
Now I am glad I did. (make it that long)
I slipped the cam lobes on the cam shaft and continued on to the valves.
I made 4 valve guides all the same 2 for the exhaust and 2 for the intake.
From mystery steel I turned four valves and then threaded the end of the valves 6X32. (sorry on picture)
Turned and threaded 4 valve keepers and along with the springs installed all. I was very lucky as I have good compression in both combustion chambers.
Also added 2 brass exhaust pipes.
This is the intake side of the engine. I added 2 short tubes for the intake pipes to attach to.
I'm following along.
Looks like an interesting design.
I am working on a similar valve arrangement, but for a steam engine.
More specifically "air" engines. While our traditional steam engines will run on air we don't reap the benifits of actual steam expansion.
My thought is to use a similar cam drive arrangement with cams that will open quickly at TDC and stay open longer, shut off quickly at BDC.
I think this will give us the opportunity to have some real slow running engines.
Just one picture today but good progress was made.
Some parts for the distributor.
Dist housing with a groove milled for the hall sensor and ball bearings installed.
Shaft with the magnet disk and magnets installed.
Brass locking collar.
Nylon gear set.
Colin the helical gears I got from China even though I would rather buy american made.. This pair, a 15 tooth and a 45 tooth, cost me less than $30. If I would have bought american made the 45 tooth gear alone would have cost me over $150.
Thanks for asking
I milled the dist cap from some type of mystery nylon plastic. I added a clear plastic spacer to the magnet wheel and then installed a piece of 14ga copper wire on the end for the rotor.
Looking inside of the dist cap you can see how nicely this plastic machines.
I have made great progress on the electrical system.
Closeup of the cylinder area.
I wanted to cover the ignition module, the batteries and have a place for the switch so I added this aluminum plate with brass standoffs to cover them up some.
Dist and hall sensor.
Other side of the cylinder.
While I was drilling the holes for the switch cover, using a hand drill, I noticed that the main frame was bowing from me pushing down. On further examination I determined this just wouldn't do. This plate has to be strong enough to not flex as it is what holds everything else in line.
I will be building a set of stiffing channels to attach to the under side of the base plate to correct the issue.
Bowing a piece of 3/8 plate? I would have thought that would have been thick enough.
Are you going to do one channel down the middle or 2 on the edges of the plate?
It's looking really good! And I think you need to add an avatar photo, maybe the "Flash" lighting bolt because you work so fast
I painted these last night and installed this morning.
No more flexing.
I ran the engine for a short time and as I had expected it got hot really fast.
I have a 4" fan blade that I will install tomorrow to see how much that helps.
