6 Cycle Internal Combustion Engine
I cut out a connecting rod and added a brass bushing in the piston end.
This is the way I cut off the caps on the main and rod bearings after the bolt holes are drilled.
Everything even fit and in line.
Next I will take it all apart and do some filing, some polishing, and make some cross beam supports with rubber feet.
Thanks for looking
Ray
All back together and shined up.
I received the helical gears and the driven gear is big that's because of the 3 to 1 gear ratio.
I will have to do some special machining to make them fit and still get the flywheel on the shaft.
Thanks for looking
Ray
In order to get enough room for the driven cam gear and the flywheel to happily coexist on the crankshaft I milled a slot in the bearing support.
Here is a shot of the outrigger legs front and back with rubber feet attached.
I will be using a pair of flywheels I had made for a different engine but didn't use.
Note the stepped slot for the cam gear.
Thanks for looking
Ray
Big day today first I cut out some cam bearing supports.
Drilling, tapping, filing, adjusting, and polishing to get this.
I have 1/8" clearance at the flywheel with the taper lock bushing flush with the end of the crankshaft.
If you remember I said earlier that I had made this crankshaft much too long but I could cut it off later if needed.
Now I am glad I did. (make it that long)
Thanks for looking
Ray
I slipped the cam lobes on the cam shaft and continued on to the valves.
I made 4 valve guides all the same 2 for the exhaust and 2 for the intake.
From mystery steel I turned four valves and then threaded the end of the valves 6X32. (sorry on picture)
Turned and threaded 4 valve keepers and along with the springs installed all. I was very lucky as I have good compression in both combustion chambers.
Also added 2 brass exhaust pipes.
This is the intake side of the engine. I added 2 short tubes for the intake pipes to attach to.
Thanks for looking
Ray
I'm following along.
Looks like an interesting design.
I am working on a similar valve arrangement, but for a steam engine.
More specifically "air" engines. While our traditional steam engines will run on air we don't reap the benifits of actual steam expansion.
My thought is to use a similar cam drive arrangement with cams that will open quickly at TDC and stay open longer, shut off quickly at BDC.
I think this will give us the opportunity to have some real slow running engines.
Sid
