Roy---You were right. I passed the magnet in front of the sensor, and the arc is jumping from one end of the coil to the other end of the coil. I just seen it do that.---Brian
Probably...not helpfulHigh voltage wires should be away from signal wires
If they are too close or touching each other, they can damage the ignition circuit or sensor
You have the sensor facing the wrong direction. It triggers off from the face, not the end.This morning I got up and smeared a big glob of silicone all over the high tension coil in the CDI box. This is supposed to stop any internal arcing on the high tension coil. I then went back to the model I created yesterday that showed the purchased plastic sensor holder in place.--Surely I can make something that looks better than that----So---I redesigned it using fabricated aluminum and steel and brass.---Looks much better in my opinion.
Brian,My God, my welding has gotten bad. I used to be able to lay down a bead of mig weld that would make the birdies sing. Now I can weld good enough to get the job done
