I want to mount the magnet in some manner so that it is not rotationally "fixed" to the cam gear. Since the cam is fixed relative to the large cam gear, I want to be able to set my ignition timing without messing up the cam timing.
Brian, your method works if the bore diameter is machined to plan. If the bore is larger or smaller than planned, the groove depth will be affected. I would think that it is better practice to first measure the bore diameter and work backwards from that dimension using the actual o-ring dimensions to determine groove depth based upon whatever ring compression you think is best ( five percent or less ). A few thousandths extra ring compression will result in a very stiff engine such as you just described. As an aside, I do not think ring groove width is all that critical. RickGordon--I'm sure that may work for you. I arrived at my figures by trial and error, and found that a typical 0.094" wide parting off tool works just fine with the dimensions I have given.---Brian
In my post I stated that the groove width was not critical. By that I meant a few thousandths either way for groove width would not cause problems whereas a few thousandths on groove depth is CRITICAL. Anyone with a modicum of common sense would know that the groove must be wide enough to fit the o-ring without distortion. As for rolling and twisting, if that is a problem, then the groove depth is as the Brits would say: "Not fit for purpose!. You can throw away the o-ring charts when using o-rings for sealing pistons in model engines. Their specifications are designed for high pressure hydraulic situations where overcoming friction is not a problem. In model engines, friction is a MAJOR concern. RickThe groove width IS somewhat important. If the O-ring is not limited in movement it can roll and twist up in the groove. I would think the width should be the same as the cross section of the O-ring to just contain it.
If the groove is too narrow then it can compress the O-ring and make it bulge such that it appears larger in diameter. Not to mention making it tough to insert in the groove.
