Some more work done this morning.
I am trying to come up with some ways of making multiple parts efficiently and accurately. These rocker arms are another example.
I started with a 1/4" thick by 5/8" wide brass barn and milled it down to .156" thick.
I Drilled the necessary holes for the pivots and rollers.
Then I flipped it and milled the profile. I used a 1/4" ball end mill to "Kiss" the edges to get a final thickness of 1/8".
Then I flipped it once more and milled the 1/16" slot for the rollers.
Now it is time to "Part" them off.
Once again using a dial indicator to locate the part, I used a 1/8" end mill to cut them off.
Here is the "Almost Finished" rocker arms. I still have to make to half holes for the pushrods.
Now on to the rollers and finishing them off.
I am thinking about making a tumbler to polish the parts, or at least take down the sharp edges. What type of medium should I use? Anything common and cheap would be great.
Kel
