Hi Kel,
To be honest I've never experimented with the spark gap. When I make my plugs I machine the ground strap in place as opposed to bending it over, so I try for somewhere between .025-.030. I would think this would give you an adequate gap to prevent fouling and at the same time provide a healthy spark.
As with carburetion, at least from my perspective, I have a basic design for a carb, from there I play with the air bleed and when I get the engine to run to my satisfaction I don't go any farther.
When I first got into motorcycle tuning and repair there was a gadget called the color tune spark plug. One of my buddies bought one and we all checked out our bikes, more for the novelty of it than anything else. As I'm writing this I opened up another window and did a search and son-of-a-gun they still make it. I'm attaching the link to it.
http://www.gadgetjq.com/ctune.htm
What I'm getting at here is I make my plugs following automotive principal, except smaller naturally. I use different sizes of plug wire, some quite small that I get from S&S. Although it has a high KV rating it doesn't have much insulation as compared with full sized practice. I use some Jerry Howell ignitions and some S&S ignitions, I even have my old standby automotive type. As far as experimentation I don't have the electrical background, or tools to do this kind of work. Who knows what' going on inside these little engines. Surprisingly with these diminutive ignitions we don't have more problems than we do.
There's only a couple of things that should be followed when building an engine with a distributor, first make it as large as possible, and second if you're using an electronic ignition make sure that you provide a 'good' ground connection when using a Hall setup. As I mentioned earlier they seem to like more advance too.
I have heard fellows talk about trying to put the Hall sensor in the distributor and continually burning them out. One way to get around this is to have a crank trigger which gets the Hall sensor completely away from the distributor. I made mine like yours with the sensor mounted outside and down away from the rotor and cap. I have had very good results with this setup.
Just make sure everything is clean and hooked up well. You can also rotate the engine by hand an feel each cylinder as it comes up on compression. Each one should feel about the same. If one of your rear cylinders seems low that could account for the wetness and missing from that cylinder.
George
