- Jan 19, 2010
- 1,193
- 41
After Making the Tiny IC I have decided to make a 4 Cylinder Inline version using the same working dimensions. (Bore-Stroke-Valve Size and lift.) But one main difference is the intake valve will be controlled by the cam instead of Automatic like the Tiny IC
I am Going With an OHV design, I have not decided how to cool it yet, I did not leave enough material to cut fins in the block, and my water cooling design is still in the works, I may have jumped the gun making the block, well see how it turns out.
OK I have been talking about it long enough and now its time do some Millin'!!
I had to get creative with my design, Because the entire block HAS to come out of a 2" round bar of aluminum. (I have a bunch of it)
I started by making a square shape, Although none of the sides are equal length.
Then I started to make the funky shaped bearing and oil pan surface. (It is shaped this way because the size of the parent bar was very limiting)
Here it is mated with the oil pan.
Now it is time to hollow out the oil pan and provide the necessary clearance for the crank.
The finished oil Pan.
And here it is on the Block
Drilling the camshaft tunnel.
Milling the crankcase.
Drilling the holes and finishing with a boring bar.
I used an end mill to rough the size out due to clearance.
boring the holes. There are three different diameters in each cylinder. (To make pressing and fitting easier.
Drilling the push rod holes. (Most of this will be milled away.
Now its time to make the Bearing caps. I decided to just make the holes to the right size and distance, and then finish them while installed in the block.
Drilling the crank journals.
Now it is time to finish milling the blocks.
And here is the "Mostly" finished block.
And a bit of scale.
Thus far, I am two weeks into the project, and 50% of the engine does not even exist on paper yet, I got anxious to do some millin', and in my hast I forgot to drill the required holes for the water jackets. :wall:
Thats it for now, Going to get to work on the head, But I need to tram my mill first, the finish on the block is less than satisfactory due to out of tram condition.
Kel
And a bit of scale.
Kel
