Not too much done today I made a couple of riser mounting sleds in order to gain some height and more stability.
I will probably work on the piston o-rings next and the risers will make that easier.
And the shop had a good cleaning today also.
Thanks for looking
Ray
Briggs and Stratton has been building engines with aluminium bores and pistons for decades. They chrome plate the pistons to prevent seizure under load.I don't think it is a new way it's more of a lazy way for me. It would not be a good way of building an engine that will see higher RPMs or long run times. I like engines that run slow and idle smoothly with most run times of less than 5 minutes.
The two cylinder engine I just finished has aluminum pistons and cylinders and all my engines use o-rings. I usually have to replace the o-rings after a few runs but after that they hold up well.
Ray
