In between insulating and sanding my ice rink I made another part, I would say this one took half the time. Center drilled, pilot drilled, drilled oversize 1.5," ( still leaves 1.25" of thread on that end) tap drilled with a 5/16" x 6" bit, then power tapped all the way through without stopping with the tailstock loose to slide. The 8K didn't drop a rev., unlike the plug taps you could hear and see the revs drop and time to stop and clear chips. Not with the spiral, it just pushed them out the other end. These spiral taps save time and effort, for a through hole anyway. Then faced and turned that half then switched ends and only had to face, turn, & chamfer, done. A dead center was used in all turning.
I also shot safe tap through the hole until it ran out the other side, all that was needed.
