Swifty
Have to agree about the double T slot, what a great idea, I wish that I had it on my lathe.
Paul.
Paul.
Paul.
Mikbul,
Thanks for all the pictures. That t-nut slide idea looks great but leaves me wondering how they setup the gib screws for it? Or are there gib screws at all?
The only problem I see with buting a new machine like that is knowing that it will never be that clean again! MUAHAHA!
-J.Andrew
I just finished turning some aluminium for the cylinder on the twin flame licker that I'm making, 54mm dia as both bores are in the same block, and the finish with carbide was excellent. I suppose it depends on the grade of aluminium, mine was an unknown piece that I had lying around.
Every time I see pictures of your lathe I'm envious, it's smaller than mine, but it looks very well built. Would love to have one as a second lathe.
Paul.
The carbide insert is a DNMG 432P, with a 0.8mm nose radius. Probably not made for aluminium, but works great as an all round tip. If I'm having trouble with surface finish, I will rough out with carbide and finish with HSS.
The discount on the lathe is great, trouble is I live in Australia, freight would kill me.
Paul.
Paul.
The more I machine the piece of aluminium that I have, I'm convinced that it's a piece of hard "tooling aluminium" used for moulds.
Some of the extruded aluminium is fairly soft and gooey to machine.
Paul.
Paul.
I've heard there pretty Sharp! Sorry, couldn't help myself and I'm no mill expert so take no offense.:hDe:I have also heard that Sharp machines are as good as or better than a Bridgeport
I'm just lucky to have a good friend who lives at the Yale Observatory and there's a full machine shop in the basement for when it used to be an active part of their Astronomy dept. He also teaches machining at Yale,(he actually does much more, that's a simplification) you'd be surprised at how many depts. have their own machine shop.I assume that Bridgeport came up with the original design, someone may be able to confirm this, but what a good design. It's been copied by so many manufactures over the years. I gave up buying Bridgeports at work when I was able to buy just as good for 2/3 of the price as a new Bridgeport.
Paul.
