Thanks Steve for all your help and dedication about upgrade, hope they wont go to junk after this
The plans won't change. They will be the same plans that I sold.
so your engine doesn't need oil sir !!
People from Mansfield are very talented 😀
The person I know sure is.
It´s a perfect job, just perfect.
Did you use friction bearing? or bearing to avoid axial play crankshaft?
What is play between sleeve and piston?
Is there pics of the cam/crankshaft angles? That must be almost impossible to build.
Sorry for my english.
There is a ball bearing pressed onto the rear of the camshaft that controls any play
There is no drawing that shows the angles. Because of the method used to make it a drawing is un-nessessary
Your english is fine,
I could learn alot of you, you are an expert.
How is that method? CNC numbers?
Thank you S. Huck
Fixture and spreadsheet.
Hi Steve
Have you had the V8 with the blower running, if so do you have any video of it
This is a fantastic project, will be good to see when its finished
Michael
