Rider Ericsson Homemade Castings
Water Barrel
I made a large compass to sweep the curvature that I thought looked good for a quarter scale barrel. Used a bandsaw to cut the curves about 3/16 wide out of a 1x6 oak board that I had leftover. I then made a jig to cut 7-1/2 degree angles on each side of the staves. I chose to use 24 staves, so 360/24=15 degrees. I then used painters tape, and then several radiator hose clamps to hold the barrel into shape.
Everything looked okay so I ripped down some 1/4 wide strips of galvanized 12 gauge that I had out of the scrap bin. Draw filed the edges smooth and drilled, riveted the ends to form 6 hoops. I kept having problems making the last end hoop stay on, and it turns out that the barrel stave profile shouldn't have been a curve like I did. I filed more of a taper on the ends and that worked okay. I also had to sort out the staves and mark several that had a fatter end and alternate those with several that had narrower ends. This made the barrel straighter. Next I charred the inside with the torch and soaked it with water to swell all the joints.
It wasn't perfectly round so I clamped it in the mill and bored the ends to fit the head piece. I water tested it, and reset all the hoops several times, but it still leaked. Turns out that white oak is the correct material to use, and not red oak because it is way to porous. Sealed the inside with shellac and now its tight enough for this job. I really enjoyed doing this, but sure wish I had used better wood. I rubbed teak oil on the outside and it looks properly aged to go along with the patina of the engine. 🙂 🙂 🙂
Started the suction and discharge piping using PM research cast brass fittings and heavy wall 5/16 pipe. I think it still needs those cool looking pulsation dampers. I also have to make the priming cup and valve.
Happy New Year!!
I thought I would take a break from four stroke engines and build a hot air engine for a quiet change of pace. I had purchased the "Steam and Stirling" book, and I am attempting the lovely Rider Ericsson in 1/4 scale as drawn. This is the largest I can make with my benchtop lathe and mill. The book assumes that one has purchased the castings, but I thought it would be fun to make the patterns and cast the pieces myself. Some scaling and CAD drawing was done to come up with useable dimensions.
The base plate was fairly easy. Three pieces of MDF board cut with my scroll saw and beveled using the disc sander. I milled down the 1/4" top frame to 1/8" after gluing it to the larger base so it wouldn't break. I think I will order 3/16" plastic letters and glue them on also. Probably add some fillets to the border also.
The legs were more challenging. I attempted to steam bend 1/4" plywood and clamp in a glued up jig, but the curve didn't set right. Too much spring-back using plywood I guess. I then cut the jig up and removed everything that wasn't a leg using a coping saw and foredom tool. I still need to add the feet, but the general concept looks good. It will be tricky to mold it as I never attempted a "irregular" parting line on a single pattern.
View attachment 155686View attachment 155687
I have the same book and lament I do not have the castings for that engine. Any chance you would be willing to make up a set and sell them? I would also love to build this engine. Thanks
Hi Shawn,
You can buy castings from Meyers Engines.
https://myersengineworks.com/
I believe the owner is a member of this forum. It would be a better value for you because it includes the cylinder tube materials. I'm flattered you asked though.
Thank you and keep us posted on your project!
I purchased a1/4 scale kit from Myers in Jan 2023 and found it to be a very good kit with excellent drawings. Took about 5 months to build and all in
cost including all necessary materials paint etc. about 950 $CDN. It is a very good runner ,satisfying to watch and will pump away unattended for as long as you want. (Longest run over 3 hours ) raveny, I admire your work especially that barrel! The pulsation dampers are well worth the effort and do make e difference to water flow.
Colin
Hi Shawn,
Ah, it is WE who should be thanking YOU. I forgot about Meyers. There are some other casting peeps too. I wonders if anyone has a list or would make a list of all the casting companies there are. I know Deutchland has a couple and there are also a couple in USA and at least one in Australia. I usually buy about one kit every couple years--from the one company I NEVER forget: Stuarts. I would dearly like to support other companies, as I a m all too familiar with what happens to a company that does not get buyers.
Colin
Did you have a video of that?
