Added the water jacket, and shelled the base.
I was wondering if I would be able to shell the base or not, and that was going to be ugly if I did not figure out how to do that, since that is how I will make the core for the base.
And the exhaust rocker arm is not horizontal, and slopes upwards to the exhaust valve from its opposite end.
The exhaust valve is over the intake valve, and so is above the centerline of the bore.
It looks like the large gear is offset a bit down from the smaller one.
I guess that would work.
I will have to compare that with the geometry of the gears on the Galloway, which I assumed had centerlines on the same horizontal plane.
So that would make the centerline of the pushrod below the centerline of the bore some amount.
Not a problem; we can work out that dimension.
