I use LinoCure (tm), which is a 3-part binder system, with a resin, a hardener, and a catalyst.
One does have to wear a commercial-grade chemical-rated respirator, and nitrile gloves when handling this product.
The catalyst is nice since it allows one to vary the set time.
There is a set time, and a strip time.
One wants to remove the patterns prior to the end of the strip time, else they will be permanently glued to the mold.
I have seen some use epoxy as a binder, but I am not sure about how to do that.
I also use sodium silicate, and I have some that uses a hardener, and a catalyst.
Sodium silicate does not have the harsh chemical properties that the resin binder has.
Bound sand must be very dry, and I use a commercial product called OK85 (from Oklahoma), and I think it is oven-dried.
I use a ceramic mold coat (same as in the slingshot video above), and that really helps with the surface finish.
As far as covering the lines in 3D printed parts, my plan is to use a thin layer of n auto body skim coat, and then sand most of that off.
Perhaps a product like this:
https://crestauto.com/shop/body-filler-finishing-glaze-supplies/finishing-glaze/skim-coat/
Below are some molds, and some castings.
