Not going to happen guys. Remember, I couldn't get the engine to fire nor run at all with the cast iron rings. It simply wasn't going to happen, there wasn't enough compression. As soon as I made a new piston and put a Viton o-ring on it, I had lots of compression and the engine would fire quite regularly when driven by the electric drill----it just wouldn't stay running on its own. Then with the new Chrysler points it blasted off and ran as you seen it in the video. I've had that piston in and out enough times. I truly believe that with another couple of hours of running in, the cast iron rings would have sealed properly, based on visual inspection of the rings and piston. The wear pattern on the rings is about 90% uniform, with two areas that had started to wear but still hadn't reached the same finish as the rest of the ring. I paid $20 for the rings including shipping, and made a cast iron piston. I'm not going to use it.--If anybody wants the 1" dia. c.i. piston and rings, they can have it for $20 plus shipping.---The next part of this marvelous adventure will be to get the governor working.
