I finished the cylinder head and pipe flange by making their gaskets. In the past I tried using scissors to cut gaskets that were traced or marked out with dividers. I also attempted to use commercial punches and none or these methods gave me good results. A quick but simple idea came to mind while rushing to finish a build. Using spray adhesive I glued a piece of gasket to the bottom of a round cylinder and trimmed of the excess with an Exacto knife. It worked like a charm and the trimmed edge was as good as it gets. The bolt holes were next, but trying to trim them out with the same knife was making a mess of the gasket. While trying to think of a method a simple solution became apparent. A punch with a matching die would do the trick. The photo below shows the method I have been using ever since.
I drill the exact size clearance hole used on the cylinder head in a piece of scrap and machined a pin to the same dimension minus about .002". Then using the M/D quill movement, I simply punch and turn, punch and turn, until all the holes are done. This method works with gasket paper and Teflon sheet.
To make the flywheel I had to use the only piece of brass on hand that was close to the correct size. This turned out to be a 1-1/2" piece of hex. Since the original plans called for a round plain drum style flywheel the hex would need to be machined down to my planned 1-3/8" size and then cut off. Since I was starting out with a hex that would self index, the addition of a visual dimension became apparent by simply adding six holes to the basic flywheel design. A process I laughingly refer to as "Swiss Cheesing." The hex was faced and turned to dimension along with a 7/16 hub protruding .050", and the 1/4" crank shaft hole was center drilled,drilled, and reamed. Then when the cut off on the opposite end came close to the hub dimension, I stopped leaving the flywheel attached to what was left of the hex. The photo below shows this stop point.
After setting up a vise stop and clamping the hex in the vise, the head of the M/D was centered on it, and then the hand wheels were zeroed out. I eye balled a nice offset for the first hole at .410" off center. Then I center drilled the 6 locations by indexing the hex and followed by drilling them 19/64". To minimize the tedious and often overlooked finishing of the holes I used a .312" (3/8") reamer. The picture below shows the start of the drilling operation. The flywheel was returned to the lathe for cut off. Then after a protective double layer of tape was wrapped on the outside diameter of the flywheel, the facing and addition of the 7/16" hub was completed on the cut-off side.The photo below shows the center drilling complete and the first hole drilled.
To drill and tap the flywheel for a 6-32 set screw I used the quick and simple eye ball method. After the decorative hole and the crankshaft hole were lined up using a drill bit from the front. Then the center of the flywheel along its length was located by the traditional method of moving the spindle back to center line 1/2 of the flywheels length. The flywheel was removed from its setup for a final cleanup. I used a ¼ and 5/16 hand reamer to remove any burs caused by the drilling and tapping. The picture below shows the line-up process.
-MB
