- Dec 31, 2010
- 822
- 220
Terry et.al.
If you have a scope you might want to try one of these. They are low volume, you can measure the peak pressure pulses and no need for a shrader valve. You can put it in place of a sparkplug with the engine running. (short the sparkplug wire to ground to protect your coil).
With a bit of training (Youtube search pressure pulse transducers) you can also diagnose valve sealing issues, valve timing, blocked exhaust systems etc, etc. They are used in the automotive industry all the time now.
https://www.ebay.ca/itm/Pressure-tr...290965?hash=item4d49a8f395:g:Z7YAAOSwyXFaslY-
You'll get best resolution if the sensor is just over the maximum expected in the application. For most work the 200lb version would be suitable.
