Here is last night's installment - I'm absolutely knackered, was in there until around 2am which is a bit silly but I just got into one of those moods thinking I am not leaving until I do what I intended!
I started by sawing the base to rough length and milling the sides in the vice to give the correct width.
Unfortunately it wont fit in my vice so I had to remove the vice and clamp it on 2 blocks of wood with the edges overhanging. So I clocked it with my dti.
I milled the ends square:
I then marked it up as a precaution.
Drilled all the holes, centre drilling first.
Then I realized I didnt have any 2ba bolts, screws or anything! Pretty pissed off, I set about making some screws in a mad frenzy! Unfortunately, because I was rushing the shank size is slightly bigger than 2ba clearance size so I had to open the holes in the base up a bit.
Everything bolted up quite nicely.
But I must have made a mistake somewhere in my calculations! The piston was not coming to the end of the bore, but at the other end it was sticking out by the same amount. This meant I had either drilled the holes too close together on the base I was annoyed and about to re-drill / slot the holes, then I thought why I can just shorten the conrod. So I did that and it means no damage to the base. It all looks how I intended so think I must have made the con rod wrong! Actually, come to think of it, when I wound the distance in using the milling machine dials I thought, thats miles out
but put it down to the dials, I know them to be inaccurate over large distances probably the pitch error on the lead screws. So I thought nothing of it and used my markings instead. Maybe I calculated the marking wrongly oh well, no matter.
It spins over nice and freely so the only thing left to do was try it!
Unfortunately I couldnt get a peep out of it, I was just holding the burner in different positions whilst trying to spin the flywheel but it didnt show any signs of life. It makes a nice sucking noise and you could see it sucking the flame in and blowing it out if held in the wrong place. I need to have a proper look at flame positions, size of flame and timing of the valve now I didnt think timing would be an issue but maybe it is. I bit dis-heartened but I will keep trying, it cant be that far away. If it still doesnt show anything Ill go for a new piston and valve.
Nick
