Hi all,
Thanks for the kinds words and encouragement.
I know this has gone a bit quiet but I havent given up on it! If Im honest, I am a bit disappointed that it didnt run and I couldnt even detect it trying to run. It passes I think the tests on Jan Ridders problem solving page. If anything Ive done is a bit marginal, I think it was the cylinder and piston tolerances.
I havent done nothing on it, I spent a few nights messing around trying to get it to run but nothing. Then I thought, just finish the thing off and then try to troubleshoot. So I started by finishing the aluminium base off.
I sanded it with the bosch mouse sander then got a stick with some wet & dry and rubbed it back and forth a bit. Then I did the same with some white spirit which gives a sort of matt sheen to it. I could really go to town polishing it but it takes ages to get the machining marks out completely so thisll do for me. I havent put polish anywhere near it, just a quick rub with some wet & dry and oil seems to give a nice finish in my opinion. I decided not to put an edge around it as Id probably spoil it if I didnt take care in clocking it square on the milling table.
After this, I could then make the base from some brown stuff. This needed little counter bores for the screws underneath the alloy base. I was wondering which way to go to fasten it down. At first I thought, could make some nice hex bolts and bolt from top. Then I thought I could keep them hidden like the rest of the engine, but then I found some 0 BA screws with nuts so decided to drill through the lot and leave the nuts on top as a sort of feature. This meant giving my nuts a bit of a polish so to speak!
Again, this was sanded with the mouse and oiled with teak oil. I did put an edge around this with a countersink in the milling machine. It worked ok but it was a mess on getting it clocked straight.
Then I decided to re-do the crank pin. As discussed before with Bogs, its better to retain the big end with a set clearance to stop it wondering. So I made this from stainless:
Along with a little bronze spacer. This is the first time Ive ever knurled anything since uni. The set of knurls I have are sort of sprung and you turn a screw which makes them closer together (need a pic!). I didnt really know how much to tighten it so I went easy, but then of course you cant go back and do it again incase it goes in a different place and mashes it up so the knurl isnt very deep! I should have pointed out that is a 2p coin! Don't know why I put it that way around!
I then assembled the engine together. Here are some pics, looking much better on its real base!
Hope it doesnt stay in here for the rest of its life! :
The base was needed as it was wobbling about when trying to flick the flywheel over. Now its very stable so it will give me a better chance when I try to get it to run in anger!
Almost forgot to mention that I re-lapped the bore and made a better fitting piston and valve. How much better remains to be seen though! I also took the opportunity to extend the spigot on the piston slightly as I noticed my port wasnt opening quite fully not sure why, I must have calculated something wrong.
All I need to do now is the burner, then I am hoping my little tweaks and improvements are enough to get some life out of the thing. If not, Im a touch puzzled. The only real thing I can think of is that I may have to revisit the cylinder and pistons again. I have a sneaky feeling that when I lapped it, it may have taken a bit of parallelism & circularity out of the bore. I think I have some adjustable reamers which may correct that, then make new piston and valve again.
There are another couple of suggestions with regards to the mass of my piston and valve as they arent hollowed out and the only other things that are different are the flywheel and con rod length. If anything the conrod length should improve things though and the flywheel should be ok, it should be better and dont think its any heavier. If things such as the mass of the piston affect its running, it is, as I thought a marginal design.
Here is a little video flicking it over by hand, sorry about the lighting!
So, hopefully will get started on the burner tomorrow, and by the weekend, fingers crossed Ill have some good news. But Im not holding my breath, could be back to the drawing board I think!
Nick
