67) Today's post will show how I made the cam and cam gear carrier, and also the crank gear hub. It's a quick and simple method that has worked well for me in the past. A 3/4" Steel bar was machined down to the specified major diameter of the cam on the lathe. I profiled the blank for the cam using a spin fixture mounted on my mill. The end mill was lowered .001" at a time till it touched the work piece, and then shifted off to the end and lowered to the specified minor diameter of the cam. After the cutter was taversed back and forth to make the first cut the spin fixture was reset 10 degrees to take another cut. It took 25 cuts (0 to 24, inclusive) to match the 120 degree shown on the plans as a 1/4" remaining on the major diameter. To reduce the time needed to blend the flats created by the incremental milling, I moved the pin on the spin fixture from the #1 position up to #5. This gave me 23 cuts in-between the previous ones, cutting the increments (flats) in half. In the picture below you can see the smaller steps, created by what I call double-cutting, that will require much less blending time compared to what I've done in the past.
68) I transferred the 3/4" collet and stock back to the lathe to blended the cuts by hand with a smoothing file. Clamping the stock in a vise would due, its just easier on my 'back problem' to use the lathe due to the collet chucks height.
69) I went over the profiled blank very lightly and length-wise with a fine stone to see how well the filing went. The surface looked good with only a few light milling marks , so I finished up by polishing the surface shoe-shin style, using a strip of cloth backed abrasive (crocus cloth).
70) The next step was to carefully drill and ream a .250" hole for the cam's pivot pin. I checked the bore with the actual pivot pin material in insure a close running fit before going on to the next steps. In the event of an unacceptable bore to pivot pin fit (It can happen) the piece would need to be scraped. In the event of needing to starting over It would have saved time to do the profile milling after the bore was finished, but doing it in this final set-up assured that the gear would run concentric (important) with the bore. After the press fit step .125" wide by .375" in diameter was added for mounting the gear, the cam was parted of 5/16" wide.
71) The method Hamilton shows ("easy cam"), is to make a fixture and turn the cams profile on the lathe. I didn't understand this method, so I made them using my self taught method. Below is a picture of the semi-finished cams. Works for me, give it a try.
72) I didn't like the idea of the entire cam profile rubbing up against the engines frame, so I bolted the cam to a simple machined-in-place fixture and machined a .010" step for the cam to ride on.
73) I purchased the gears for this project as recommended in the plans, from PIC Design, a division of RBC Bearings. Both of the gears are stainless steel, .125" wide with a .375" bore, models #J1-30 and J1-60, 30 and 60 tooth.The gears were made to order with a lead time of three weeks. These are extremely well made, and referred to as "instrument quality" by Hamilton. I'm very impressed with the quality, and will eventually get over their price. :-
74) I machined up a bushing for the smaller crank shaft mounted gear, with the same mounting step as the larger cam gear. In the picture I'm parting it off at the same 5/16" width.
75) A .020" step was machined on the gears bushing to just below the bottom of the gears teeth. I did this as a precaution to prevent damaging the teeth on the cam gear in case one of the gears track off center, and also to eliminate the corner that might trap dirty oil or dust.
76) Nothing new here. I just wanted to show any beginners watching the set up I used to drill and tap the duplicate small gear hubs for a set screw. The first work piece was set up on a parallel, and against a vise stop. An edge finder was used to locate the center from both directions. Then simply, center drill, drill, tap, remove, and replace work piece, and repeat. I use the stationary chuck (just barely open), to guide the tap driven by two fingers on a small 'taping disc'. This eliminates tap breakage, and the need to set up each one individually.
77) The gears are all finished with no place to go. This was really a simple project that took far to long. Reason being I wanted the gears to fit and mesh properly. I think I did well and do not expect any problems durring assembly.
78) A last step before the photo shoot was Parkerizing the gear hubs and cam. They were made from steel that's susceptible to rusting. The parts were processed for only 5 minutes in the hot solution and turned out well.
Happy Thanksgiving every one!
-MB
