vederstein
Must do dumb things....
- Feb 26, 2011
- 929
- 769
I don't like to criticize, but PM research are at fault:
Steamchick, with respect, that's a bit unfair. PM Research are not really "at fault". They are just providing a period-correct simple stationary steam engine model. I don't recall seeing such full size engines with a counterbalanced flywheel although there may well be some. Most basic traction engines and portables, for example, have plain spoked flywheels and even bent-from-round-bar crankshafts with no obvious attempt made to balance anything. Hence they gently rock back and forth when at work. Unfortunately, the model in the video is running way over scale speed which accentuates the imbalance. At 1/2-1/3 the rpm this would not be an issue...Vederstein, I don't like to criticize, but PM research are at fault: The flywheel needs a counterbalance weight to minimise the imbalance of the piston, rod, crosshead, con-rod and big-end masses. I simply hate manufacturers that sell kits that have not been properly engineered with a counterbalance cast-in to the flywheel.
