Mach 3 help
It looks like
Pin14 on the DB25 is X enable
pin 15 is A enable But 15 is not a valid output pin
16 is Z enable
17 is Y enable
And for A, step pin 5 direction pin 9
thats fine but were do I set the 14,16,17 enable
thanks
Config/Ports and Pins /Output tab
Don't forget to hit "Apply"
We better check the motor tuning page too.
config / motor tuning
I am assuming you are Metric ?
These should be safe for metric, we'll fix it later when you know what screws you are using.
Maybe the Enable will fix the one direction issue.
I'm using imperial
I hook up another controller board
and everythings work enable step but no dir Ill go and check it
thanks
Luc
Luc
Do you have a link to your motors ?
If they are 4 wire bi-polar and one direction works so should the other.
If they are 6 wire and you wired them for bi-polar, they may be wired wrong.
Scott
For imperial use these numbers for now. This would be for a 5TPI screw and 50 inches a minute rapids
Thanks for all your helpth_wav
evrything works finewoohoo1
I'm sending back the BOB'S board back:wall::wall:
and the reason It did not want to switch cw or ccw
is a deffective or could solder board:eek: I didn't check it yet
I simply decide to check another driver boards and it worked fine
and all the other axes also
I will be running a belt drive with a ratio of two to one
cheers
Luc
Great !!
Glad it's going
Scott
Thank you very much for all your help
will fixe the driver and post a video.:D
If you look up in the sky and think it's an Flying Saucer
think again it's that board that I just trown awayRof}
now it's time for one of those
*beer**beer*
cheers
Luc
