What is the life expectancy of the relay? I thought they couldn't cycle but so many times -- ??
Ah, that's interesting. I had missed that.It is using just the coil so life expectancy of a relay doesn't come into it
Lloyd, i just now was reading this thread and saw your post. several years ago i was a member of the technology council in SW Virginia and there was mention of someone using technology for the chicken door opener. if i recall the Gov. of Va at the time was even at that meeting. i want to say it was Dutt and Wagner they were mentioning as the egg producer but i could have just assumed that since they are just down the road from me and where the meetings were always held. just sounds like to much of a coincidence that this had to be you that they were talking about. this had to be at least 10 years ago i guess but seems like yesterday.Come on now, don't go talking bad about my chicken projects. It was something far more sophisticated than a simple "Chicken Waterer". It was a "Solar Synchronized Chicken Coop Door Opener". It had to be sophisticated to make up for the deficiencies in the tiny chicken brains. The door had to be coordinated with the seasonal variations in solar sunrise and sunset. The clocks in chickens are embedded, and cannot be re-programmed. Dusk to dawn timers won't work either, and the chickens will either get trapped inside or outside, and always on the wrong side. And several safety interlocks are necessary so that no chickens get mashed in the operating door. In the end, I don't think the chickens cared one way or the other.
Wow, small world. No, that wasn't me, although I went to VaTech and lived in Floyd County and know my way around that region. Beautiful country, but so is Charlottesville.Lloyd, i just now was reading this thread and saw your post. several years ago i was a member of the technology council in SW Virginia and there was mention of someone using technology for the chicken door opener. if i recall the Gov. of Va at the time was even at that meeting. i want to say it was Dutt and Wagner they were mentioning as the egg producer but i could have just assumed that since they are just down the road from me and where the meetings were always held. just sounds like to much of a coincidence that this had to be you that they were talking about. this had to be at least 10 years ago i guess but seems like yesterday.
i see your location is Charlottesville VA so maybe it was you. but i do recall this being mentioned as a huge inovation and how technology and farming were coming together.
I'm sorry guys that I haven't done much on the programmable ignition lately but the wife has laid down the law with me after I bought 2 snowmobiles. They weren't running but I worked a little magic on them and they fire now but, all the fuel lines need replacing and carbs need to be cleaned, real bad. Anyway I have been working on the yard and house and when that is done I'll finish the programmable ignition. Interesting, both sleds have AC-CDI ignitions with fixed timing and have very little adjustment . . . . for now. TTYLI have but it may be protected info.
Anyhow, you won't even start to build it for the price you can buy the complete system, coil and all.
Many have tried their own uC cdi's in the past with varying levels of success/failure, the latter more prominent.
74Sprint (Ray) I think is currently working on yet another approach, as yet unfinished as far as I know.
Details of that are in the forum here.
BLUEJETSI have but it may be protected info.
The only reference to what you say as I can remember is, this is for the 4 pin DC CDI module which are all the same as far as I know.I know you mentioned that some don't work with your circuit. Perhaps even some from the same supplier.
It would be useful if you could post a link to get started. I can take my chances on supply reliability and suitability.
Already posted a circuit and details on a cop type coil from a BA falcon...runs on 3v7 LiPo and NO driver required.Ok. Thanks for getting all the info together in one place. I'll order the stuff just to play around. That said my driver board (Sage / Gedde - presented elsewhere here) and a cheap COP coil is cheaper and smaller as a whole package. Also I've never run into a practical rpm limit with the coil driver. Besides that CDI's generally produce a very narrow spark whereas a typical coil is much longer duration - a good thing. Most CDI's try to compensate with a multi-spark arrangement.
But I'm always up to test various solutions.
Thanks
As the heading says ...easy and cheap...bugger all to play with and go wrong...anyone can access the parts from anywhere in the world.I had no intention of being critical. I applaud your efforts. I enjoy all means to an end.
I've seen a few posts here and there about using the three / four wire coils (driver included). Case in point post #112 by Eccentric. I might have missed your particular post .
Seems the way to go considering simplicity and size etc.
So, why did you pursue the CDI solution? Just curious.
