Hi Jerry,Hi BlueJets, I ordered 5 single boards today from JLCPCB yesterday. I'll update as parts start to come in.
Jerry
I plan on building one, just ordered the 4 pin cdi's using your link. I have a couple questions on the completed functioning ignition. What is the upper rpm limit? Could you possibly measure the input impedance of the GY6 scooter coil? The reason I ask is that I plan on substituting a dual output coil for use on a wasted spark inline twin.The only reference to what you say as I can remember is, this is for the 4 pin DC CDI module which are all the same as far as I know.
Obviously my circuit will not work with the HV (300-400v) 5 or 6 pin units.
One link is here anyhow, just about to order a few more.
In this instance from here at least, if one orders over AUD$15.00 worth, (3 or more) delivery is free.
All I have seen as well, have the blue connector with the 4 internal pins to which I solder whatever length leads I need.
If one wants to use a plug with these, it will be the 6 pin auto type plug 2.8mm.
https://www.aliexpress.com/item/1005003571737448.html
No, glow plug is standard and rc nitro fuel. they have a spark ignition / gasoline option that is about $200. Besides, I want to build my own to learn for future engine builds. I bought the engine to basically reverse engineer it for educational purposes, cam timing, valve size, piston/ring dimensions etc.Looks like spark ignition already?
Ah...good to know...thanks for the update.Hi Bluejets, Thanks for the updates on your pc board. I got the boards and that’s a simple error to fix. Still waiting on a couple of parts to come in.
No idea on "upper rev limit" as it was never a consideration.What is the upper rpm limit? Could you possibly measure the input impedance of the GY6 scooter coil?
