All that was needed was to use a bearing with a flat stainless steel seal that is used quite commonly now in all sorts of things, like high temperature and food processing environments.
Ray
Ray
Did you ever get anymore boards made? I'd be interested. DaveThe simplest ignition I can come up with besides points.
Just a quick update on the LS1 smart coil and driver board. I tested the coil a bit more and the required driver components. It will work with just a Hall-effect but it's not consistent. To correct this a PNP transistor is needed to drive the spark signal. The signal drives a transistor inside the coil so more current is needed. I went to a 1K ohm pullup resistor and I don't want to go below that because the Hall-effect or most of them can only handle 20ma of current. I could go down to 600ohms for 20ma. I did notice that just like older GM designs it needs to see a positive going pulse to trigger. The board is 17mm wide and 26mm long. C1 should be 0.01uf to 0.1uf ceramic depending on Hall-effect used. In the setup below the coil will fire after the magnet passes the Hall-effect or when the LED turns off. No dwell control or limiting resistors are needed because the coil handles all that. Just add a Hall-effect, 12 volt supply, and a LS1 smart coil. You don't have to use the 2N4403 (PNP), you can use something similar. I used it because I had them.
View attachment 129368View attachment 129370View attachment 129371View attachment 129394
I included a pdf below that can be used to turn a CD disk into a timing wheel. I have others to share with timing events. If there is enough interest I'll get extra boards made. Oh I also cleaned up the board design a bit, things like better pours and changed Q1 to a wide T092 pad.
Ray
