zeeprogrammer
- Mar 14, 2009
- 3,362
- 13
Steve...thanks. I should have mentioned that I saw some of the dents just after adjusting the 4-jaw...prior to machining. So while I think the interrupted cut is something to watch for, I don't think it was the culprit here. I took another look at the 4-jaw. The dents (and damaged aluminum) were caused by the two opposing jaws used to keep the part center...not by the two jaws used to move the part over. In fact those edges look excellent. So I think a combination of too much force and rubbing the part across the jaws resulted in the problem.
I think I'll follow Marv's suggestion and have my wife clamp it. :big:
kvom: Thanks for that link. Nice idea. I also like seeing the collet block (and yes I bought some the other day).
Marv: 'hulkish'...nice :big: Took me a bit to realize what you meant by having my wife clamp the part. No good using either method (even though she has a fiendish pinch). I do like using the mill and have gotten much more comfortable with the edge-finder. I liked the last tip too...cutting off the arms...not so silly!
Thanks again all.
I'm thinking I may be doing some rotary table work soon...the eccentric arm and the reversing lever.
Thanks again all.
