The top case requires four cores.
The middle two are identical but there are some differences in the two end ‘bays‘. Notably there is an undercut to the front crank bearing housing on the right that the oil fill passage connects to from above.
The pattern shown above is based on the original casting with a lot modifications involving jb weld epoxy and pieces of wood. So this represents what I’m aiming for with the interior of the new casting.
I built two core boxes. One is for the rear core only, the second, shown below, can be used with alternate parts to make either the two center cores or the front core.
J
As shown the scheme to produce the cores involves a number of fitted pieces of wood that can be assembled using screws, then packed with sodium silicate impregnated sand, and then disassembled without putting stress on the cores. The core can easily be broken so the core molds were designed so that each section contacted a minimal number of sides.
Filled with sand.
Some additional notes on the core making….
Even with these core boxes there was still problems with the sand sticking in the molds and breaking. Sodium silicate sticks to pretty much everything ! Success was eventually achieved by coating the interior surfaces of the box sections with a low viscosity epoxy resin. Epoxy is possibly the only thing the sodium silicate will not attack. I also rub carnauba wax onto the mold surfaces just for good measure.
I found that the sand needed to be thoroughly wetted through with the sodium silicate or the cores ended up too delicate to use, but maybe my sand was just coarse. Sieved play sand from HD.
After packing the molds with SS sand I placed them in a ziplock bag which was then filled with CO2.
Initially the CO2 was produced using vinegar and baking soda. I would place a 1/2 filled cup of baking soda in the bag and add vinegar through a tube, just enough at a time to get a reaction that came up to the top of the cup. This technique worked well and is very cheap. If time isn’t an issue you can just leave the cores in the mold and they will harden up just from the regular atmosphere after a few days.
I ended up making quite a lot of cores at the time as I debugged my core making process and eventually I bought a 0.6 L cylinder of co2 plus a valve. These cylinders are meant for carbonated drink makers. You can get a filled cylinder for $15 plus shipping, it’s ten times the expense of vinegar. You can fill a large zip lock bag about 50 times I found.
So with sand cores to hand, here is the sand casting plan of attack!
Step 1. Press a plywood template of the crankcase outline into the sand. The underside of the template includes indents to position the four cores.
