Thanks. One subject that often arises with cylinder heads is their ability to hold pressure so I thought I’d leave a note based on my experience with the Gypsy. My last project (the Chenery V twin) was fraught with issues trying to get compression, and it turned out the main issue was the casting material. The valves in that engine are seated directly into the head, and the Gypsy is the same. The difference is that in this case the Gypsy heads are machined from 2024 billet rather than a casting, so I hoped that this would make life easier with respect to seating them. The valves are stainless.
Rather than attempt this on the engine where you have to worry about pistons and rings at the same time I decided to make up a test rig just for the cylinder and head.
This was the set up with just the cylinder to check for leaks with a blank in place of the head. There is an o ring in aluminum base to seal the bottom of the cylinder.
I experimented a little with a head gasket, trying a ‘paper’ gasket and a copper gasket. The copper being 0.01 thickness. Didn’t have much luck with the copper, even cutting it down until it was very narrow, annealing it etc. I don’t think I could get the head down tight enough to crush the copper into a seal. There are four 1/8 in studs holding it down. The paper gasket gave no problem and was re usable many times.
Having got the basic set up holding more than 60 lbs I assembled the first head, spark plugs etc. The first test was not promising and it found three basic issues.
1. The cylinder to head joint was not sealing with or without a gasket. This turned out to be related to the proximity of the spark plug holes to the cylinder sealing surface. When the plug threads were cut they raised the metal up enough to distort the mating surface to the cast iron cylinder. This was remedied by refinishing the surface with a plug that fitted the head recess with some 400 grit paper super glued to it and gently rotating till the raised portions were flat again.
You can see the surface of the head where l blued it and the area below the spark plug. Incidentally this also shows the technique to bed the valves i.e. cutting the head off a cross point button headed screw and super glueing it to the valve. I don’t recall who originally did this but it works very well. When the lapping is complete just ping the screw head off with a razor blade.
