skyline1
- Aug 6, 2012
- 446
- 153
I'm by no means an expert on these things but I have done a fair bit of Aluminium casting in the past so here are my thoughts, right or wrong (more experienced members should feel free to disagree it won't cause offence).
The "micropores" in the picture do look like gas porosity and whilst in many cases these are not a problem, in this case, as we are talking about engine parts they could cause difficulty some degassing would improve matters.
As would an "active flux" which not only makes drossing off much easier, but actually refines your melt by actively drawing impurities out. The products I used were "Degasser 190 and "Coveral 11" respectively both from Foseco limited in the U.K. You may not be able to get them in the States but I am sure there are suitable alternatives
The surface "craters" are a little more difficult to diagnose, As you say they could be residual products from the foam, but could equally be due to some kind of sand penetration from the mould, they could even be caused by steam if the moulds were at all damp,
I think the pouring temperature might be a little low as shown by the fact that some of the gates have not filled completely, and ideally you should provide a "riser" opposite the pouring sprue this keeps a "head" of metal to allow the casting to "draw" from and also provides extra exit for the gasses.
That all said these are good castings for a first attempt at this type of casting. I wish some of my first ones looked that good.
Best Regards Mark
Best Regards Mark
