You can not harden cold rolled steel unless you use Casenite and surface harden it. Heating it to destress it is just wasted heat.
Yes you can stress relieve CRS but doing it before you do the machining would be the way, the reason it warps when being machined is because of the built in stresses from the cold working processes. Because it's stress relieved instead of annealed, if you can do that, it will still machine like CRS instead of HRS, at least that's my experience.Is it possible or a good idea to machine cold rolled to within a few thou, then heat it to destress the stuff and finish later? What about if it is necessary to re-harden it later?
If you choose to do such - - - please don't machine to within a 'few thou' - - - - that won't leave you with enough to remove to give you 'good' parts.Is it possible or a good idea to machine cold rolled to within a few thou, then heat it to destress the stuff and finish later? What about if it is necessary to re-harden it later?
Making round parts went quite swimmingly--Until I broke off a #10-24 tap. Tried all of my usual tricks to remove it, and none of them worked. Will remake that part tomorrow morning. BAH!!!----HUMBUG!!!
Yes, oversized holes help a lot but I also found that 3-flute taps are stronger than 4 flutes. I never buy 4 flutes. I thimk that odd flutes are better than even, howeveer, I am not too sure about that. I just notice that three flutes are better ones (in mhy not very humble opinion) than four. Anybody else notice this?As an aside, I find that I break more 10-24 taps than any other size. I asked about it on PM one time, and the consensus was that this size requires more torque per cross section than any other, due to the relatively coarse threads. 10-32 is so much easier to tap, so I've tried to switch over to that ... but I have a ton of 10-24 fasteners on hand, so it is hard to leave it behind entirely. Of course, one can always drill a bit larger to get only 50% thread engagement, and that will help considerably ... but too often I forget that little trick until just after I hear the "tink" of the tap breaking. Grrr ...
come to thimk of it, I believe 2 flutes are far better than four. For some reason, four flutes are weak in the middle where they are connected to the center.I've switched to using spiral point or spiral flute taps - the former is two-flute in the 10-24 size, and pushes chips ahead of itself (perfect for through holes); I'm not sure how many flutes the latter is - may only be two flutes - this type pulls the chips out. Both of these have improved my success rate ... but still the 10-24 size is the easiest to break, at least of the taps I regularly use.
That's a real insult alright! Who, in their right mind, would use facecrook?Tim--My wife said the same thing. She said she was going to bring her camera down to my shop and take a picture of "An eccentric machining an eccentric" and paste it on Facebook!!!
I understand--it's a real comedy. If the black helis showed up at my place, I'd just tell them, "Here I am, where's the handcuffs?" The onlyway to stop those criminals is to jam the prisons with innocent victims--they can't afford to put us all in prisons or FEMA concentration camps. Too costly.My wife is a political hack. She worked most of her life for the federal government in Canada, and loved every minute of it. Now she gets on facebook and fights with all the Americans about their own political shenanigans. I keep telling her to leave the Americans alone, or we'll be having the black helicopters landing in out back yard.
What are the engineering and mathematical considerations in thinning the inner portion of a flywheel, leaving a thick rim?Every day, a few more parts. Hardest job of the day was standing out in my unheated main garage sawing out flywheels from that piece of 6" x 1/2" hot-rolled steel. I need a new blade on the saw, and it doesn't cut very fast right now---and if you lean on it a bit then the drive belt slips. ---Thought I might freeze to death before I got the flywheels cut out. Tomorrow I hope to completely finish the flywheels.
