Hi Werowance --I used a radius die in my mill on the four sides of the baseplate but I wasn't real happy with the results.--Then took it out to my giant stationary belt sander and used it to round the corners even more.
Daytime temps are around 30F, night time down to maybe 20F. We've got about 9" of snow here, but it's fairly new---grass was green at end of November.
ball nose endmill on left, corner rounding endmill in center, and 45 degree chamfer end-mill on right.
I insulated my garage as it was too cold to work in, then I added a heater. It's much better but when the REALLY cold weather comes, am not sure how it will be.Every day, a few more parts. Hardest job of the day was standing out in my unheated main garage sawing out flywheels from that piece of 6" x 1/2" hot-rolled steel. I need a new blade on the saw, and it doesn't cut very fast right now---and if you lean on it a bit then the drive belt slips. ---Thought I might freeze to death before I got the flywheels cut out. Tomorrow I hope to completely finish the flywheels.
WHY not take some time out to build a small rocket stove for your shop? They are marvelously efficient.Every day, a few more parts. Hardest job of the day was standing out in my unheated main garage sawing out flywheels from that piece of 6" x 1/2" hot-rolled steel. I need a new blade on the saw, and it doesn't cut very fast right now---and if you lean on it a bit then the drive belt slips. ---Thought I might freeze to death before I got the flywheels cut out. Tomorrow I hope to completely finish the flywheels.
Is it possible or a good idea to machine cold rolled to within a few thou, then heat it to destress the stuff and finish later? What about if it is necessary to re-harden it later?If you make a part which is going to be machined on all sides, then hot rolled is cheap and machines very well---Hot rolled is the least expensive material but has a rather nasty exterior finish that you wouldn't want displayed on a model. If you machine a part on some faces only and depend on the "as purchased" finish of the part to show in some areas, then cold rolled steel has a much superior finish. It is a bit more expensive than hot-rolled steel. Hot-rolled steel moves very little during the machining process. Cold rolled steel has a lot of built in stresses from the cold rolling process, so will "banana" on you if one side is machined and the other side is not. As far as machinability goes, they are about equal in my opinion. I have switched from HSS cutters to carbide tooling, because I simply can not keep HSS tooling sharp enough all the time.
