finished flywheels
the hole for the hardened pin is 0.02 mm smaller than the pin
The last photo in post #60 shows a milled face on the crank web. What was that operation?
my solution is 4 pins dia 3 mm and a central M4 screw to guarantee the phase for each cylinder and the transmission of the torqueYour Setup with the four Pins is very interesting. It should give a very precise allignement and the screw is only stressed be draw. I used for this connection 4 m3 screws. with no pin the allignement is made with the race of the ball bearing.
The screws are stressed be drwa and maybee also by shearing. So i believe your way is the better solution.
Michael
Hi MichelHi Jules,
you are making great Progress. With that Velocity the engine should run in a pair of weeks.
Michael
with a dressing diamond fixed on the chuck, as in a grinding machineLooks great!
How do you dress the grinding wheel to the lathe spindle axis?
