Bentwings
Thank you for the note. Have plan or hydrauitest. I’ve don this in industry so I’m fmilar with the process I also have a set up for ultimate test. If I get 100 psi I’d be happy I actually have two pressure relief valves as well as electrical timers to prevent un attended us. I do call local boiler inspection since I’m not usi fired boiler they are not concerned unless I was in a garage or inclosed space my boiler I really to small fr them to inspect. A pressure cooker would be more dangerous . I don have that other . I have a lot of respect for danger of steam. I’ve done home work . There will be no welding on the aluminum and it can’t get to high enough heat to weaken the material welding I would be very concerned as I’ve done lots of tech Tig welding on aluminum I don’t like even comercial luminance or tanks even my new air compressor is steel tank . They are subject to rusting if aways been fussy about wat in air Ann’s as I used to o painting so even my little thing has input Ayer filtration . And it’s only used to run my steamer and fill an occasional bike tire . It also has dual relief valves . I’m new to boilers but I’ve done a lot of research to gain knowledge needed .
Thanks gain for the input . Once this thing is completed an tested I’ll report on it.
byron
