Bentwings
I did not progress as far as I had planned yesterday as I ran into holes that I couldn’t get screws into some went in easy others just refused to start m 3 is pretty small stuff if you are vision limited. I have 3 m3 taps but I could not get either to start. I had my magnifying glass at full pier. I could see that the rap threads were trying to engage but just were being held up I didn’t want to cross thread or mess threads up. Finally I got one to start. I think dust or possibly pain got in the threads. Anyway I had to fiddle with the tap and got all me holes retapped there are a lot of them so a lot of Turing both ways . I didn’t take any metal out but the tap was dirty on every hole there was even some brass that had tight threads. So maybe I’ll have better results today. There are so many small screws and parts. It’s truly amazing the quality of machine work on this littl engine. Now I find I have to change the spacing between each engine. Fortunately I’ve allowed for this and it’s just a matter of unbolting the engines. I’ll make a drawing of the new bolt pattern so I can transfer it to the new mount plate . I have to go to a piece of ground tooling plat as it is dead flat. It cast aluminum and hard enough to tap larger holes but m3 are a real challenge I don’t have a clutch driver tunable for tiny m 3 taps so it’s hand twist all the way. This stuff doesn’t tap well en on larger sizes on a good day . More snow so I have to shovel a bitThere was a question asked a while ago about welding the boiler.
my boiler is aluminum . I had considered steel but4130 tube the size I was considering just was not available.
now even TIG welding aluminum softens or annuals the aluminum so it would have seriously compromised the boiler. I had a catch tank explode right next to me in a race car in the shop the tank was well made an nicely welded. Pat on back. It exploded so violently it ripped the metal outside of all welds. Everything came apart. It was returned to kit form as we say. This was a fuel air explosion not just pressure of boiler or compressor I’ve never seen anything like it . I blew about a two square foot hole in the Fiberglas body right next to where I was sitting it was a crankcase vent tank. Apparently a stuckintake valve allowed fuel air mix to be blown back into the tank. Then the stuck valve caused the push rod to gall up the socket in the rocker arm it got red hot igniting the fuel air in the connection tube to the tank which unloaded itself pretty scary it’s a good idea not to be close to running race cars that use nitromethane for fuel there was no fire that I saw just parts flying all over and a deafening noise . So this in mind I decided not to weld the aluminum . My eyesight is not good but I’ve been practicing welding the tablet lines and I’m getting to where I can follow them even around corners and curves. I honestly don’t know how this is working in real life but I’ll soon find out . I know the procedure and I’m redeveloping the eye hand coordination . I can’t even describe how I’m doing this some times having the drive to do something is what is needed.
hours in the batting cage allowed me to hit one of the few out of the park home runs in senior baseball . How I could still throw strikes yet hardly be able to see the plate is beyond me even the coach couldn’t believe it when I tried out. So I’m going to give welded steel a try. 4130 is easy steel to weld. It’s hard to mess it up unless seriously over heated. My new lighted magnifying glass may help . We will see .
Byron
byron
