- Sep 2, 2011
- 1,398
- 389
,keep the flux just to the local area as the solder will run where the flux is
Thanks Paul, yeah I know it was thick and spread out, I normally use a q-tip to apply it but as it was just a test piece I didn't bother running back in the house to get some, I just used the large brush that came in the can of flux. started to wipe some off with a paper towel, but again, just to lazy for a test piece. I will also probably use a small diameter piece of solder on the next one to.I will though be careful on the real piece when I get it ready. had heard that white out correction fluid was handy in that you could paint a ring around the part to keep the solder from flowing so far, have you ever heard of this or tried it?
