- Sep 2, 2011
- 1,398
- 388
this weekend I had lots of garage play time so I decided to see if I could get anything to work on the little cicada. and I had some luck. not much but I did manage to get it to run for about 10 seconds multiple times.
so at the lowest compression possible on the compression screw it will fire.
I replaced my propeller which I believe is to small with a piece of wood transition strip like you use to separate carpet from tile on your house floors. made it about 7 or 8 inches long drilled in the center and used that. has lots more flywheel effect.
I remade the rod for the umpteenth time and fueled up the tank, primed the engine, and gave it a flick or 3 and it took off. sprayed fuel all over the side of my truck bed like an aerosol spray can.
now if I had to describe it, it didn't take of like a cox 049 that I used to play with as a kid but more like my little steam wobbler engine that just about has enough steam preasure to take off but not good steam preasure. kind of slow. but the fuel spray is just like I remember the 049's do on the string controlled planes I had as a kid.
I tried upping the compression and it will not fire at all on hire compression. and once it uses up the prime fuel it dies. (about 10 seconds or less)
when I hold my finger over the carb it will suck some fuel up then push it back in the tube with air. so it seems to me its not really sucking the fuel? but if I put the tank higher than the carb it will run through the engine and flood it.
maybe an inline check valve would help?
any suggestions on the carb? I believe it to be to spec as per the plans. I did a pretty decent job on grinding the needle valve and what not.
