G'day Werowance
Sorry i haven't seen your posts until the other night, as i haven't been on the site for a while.
I have a couple of questions:-
What sort of lap are you using to lap the bore of your cylinder?
Are you using a split brass lap with a screw in the end to expand the end and add a bit of taper to the bottom end?
What sort of torch are you using to carry out your silver soldering?
You only really need a propane torch to carry out this job as you only have to get the parts to a dull red colour. If you get it much hotter you get scaleing and burning of the parts. When you are silver soldering add your flux and start heating, watch the flux, at first it will dry out, but as you keep heating it will go clear and turn liquid, at this point it is time to touch your silver solder to the job, just brush it against the job and and if it is at the right temperature the silver solder will melt and adhere to the joint. (While doing the heating keep your torch moving the whole time) Once your solder starts to melt if you move the flame in the direction you want the solder to run the silver solder will actually run around the joint, just keep adding a little more solder sparingly and you should get a neat joint.
I should add that the better the fit of the joint the better the solder will run.
Also what sort of silversolder are you using? The best one I have found is easyflow 50% silver, it is more expensive but if every thing is clean ( wipe over all the parts with metholated spirits to remove any oil) and the joint is good, when you reach the right temperature the solder will run very well.
Why did you machine off the top of the crank case and the head to vary the compression, that is what the contra piston is for.
When you make your new cylinder you will need to add the corresponding amount to the bottom of the flange to make up the difference, other wise you will have changed the timing from the original design.
When you make the new cylinder, bore it out to within a couple of thou of the required size, don't ream it, as you can sometimes get an out of round bore which then makes it very time consuming to lap straight and round, also you should aim to end up with a very slight taper at the bottom end of about .001" to .002".
You should also machine everything and carry out all your silver soldering before you start your lapping
When you make your piston and are fitting it to the cylinder, just break the top corner of the piston with a small radius(.002" to .005") aim for it to be just starting to tighten in the bore as it goes past the top of the exhaust port.
I also noticed that your wrist pin looks to be a sawn cut and then polished finish. You really need to machine a large radius on both ends to help stop it from picking up in the cylinder. unfortunately the drawings don't really show this very well.
You were right about the 10X32 UNF thread on the compression screw and head.
Your contra piston needs to be a tight push fit in the cylinder which can be moved down by the compression screw and then when you release the compression screw, the compression of the running engine will then move the contra piston back up.( there should be no blow bye at all past the contra piston)
If you have a look at Model Engine News, look at the DCO contra piston method,it works brilliantly. Ron's site has so much invalueable information on it for motor building it should be read by anyone intending on having a go at engine building.
I hope this helps.
Rob Jenkins
