- Sep 2, 2011
- 1,398
- 389
What sort of parting tool are you using? Is it a piece of HSS that you have ground to size and shape or is it one you purchased already made?
Usually the reason that parting tools walk is either it is being run at too high an RPM, the tool is not on centre or or the cutting angle geometry is incorrect, usually the clearance angles are too great.
Another thing to watch is that during the normal use of your lathe the compound slide with the toolpost on top can end up overhanging the dovetailed slide, which when you start using a tool like a parting tool can can cause vibration, if so reposition the compound slide so that it is fully supported. Also check the adjustment of the gibb strip on the compound slide and cross slide and adjust it for minimal play then take a cut.
When you are parting, being on centre is probably the most important thing, also try to make sure your tool is set square to the axis of the job.
If you are using a two or four way turrret style toolpost have all your tools matched with the correct size packing and keep said packing and tool as individual sets so that you can swap tools at any time and know that each tool is on centre every time. If you are going to set each tool up this way do it with a piece of material in the chuck and take a cut across the face if you are below centre you will end up up with a parallel nib in the centre of the job, if you are above centre you will get a conical tit and if you are on centre it will cut the centre off cleanly.
Rob.
it was a parting tool I bought in a "lot" of used bits on ebay. it was I believe a half inch piece of hss but looked factory ground to a parting tool. I took that and ground it narrower. the first 2 cylinders It cut really good with minimal chatter as compared to this one.
I believe my problem with vibration and chatter is on the first 2, I usually put my parting tool just a tad under center. but on this one I actually centered it to the point of my tailstock live center then swung it around and started cutting. I didn't lock the gib on my cross slide to way. and frankly my gib adjustment screws really needed a little snugging as well at the time.
so I think the vibration from cutter being to high along with gibs not tight caused the issue.
oh well, part doesn't look that bad hopefully it wont be noticed by my friends if/when they see it run.
also I am using a qctp axa size from phase ii. I need to get some more tool holders, just havnt gotten around to it. I have enough for my most common tools. but as this parting tool was ground just for these fins I had to swap out a tool in the holder and didn't think about going lower that dead center when adjusting it.
thanks for your help. hope to get some more shop time this weekend.
