I've been out of town and at my son's wedding for the past five days. When I returned, I decided to resume construction with the connecting rods instead of the distributors because I may have some unfinished machining to do on the main bearings. I may have to cut some additional openings in some of the main bearings to help with assembly of the crankshaft sections when the rods are installed, and I'd like to tie up those loose ends. I'm having trouble visualizing an order of assembly without the actual pieces in my hands. A lot will depend on whether the rod assemblies can be assembled onto the crankshaft sections outside the engine and then inserted in the crankcase sections or whether everything has to be assembled within the crankcase as was necessary with my 9 cylinder.
I started with the slave rods and a goal of 20 completed parts. I designed my own rods for my 9 cylinder engine, and I'm using the same design here. These rods have the maximum possible amount of material in their stressed areas and a worst-case .020" minimum clearance to other components of the engine when running. I gathered up all the half-inch known 7075 (approx. 75% higher strength than 6061) aluminum plate I had on hand; and, with no screw-ups, I should have just enough for the job. I very much wanted bronze bearings at each end of the slave rods, but doing so would have compromised their strength especially at the master rod end because they would have replaced significant amounts of high strength aluminum in critical areas.
I used the CNC program that I had previously developed but with a few minor tweaks to nest the parts among my scrap plates. Four arrays of either four or eight rods were machined at a time. The holes at either end were first drilled and reamed, and then the top halves of the rods were completely machined with roughing and finishing passes using 1/8" cylindrical and spherical cutters. I then glued the perimeters of the rods to their workpieces before flipping them horizontally in the machining vise and running similar machining operations on the opposite sides. These bottom-side operations cut the rods free from their workpieces leaving only the cured epoxy gel to hold them in place. The parts were finally released free of their workpieces by heating them to about 175F with a heat gun.
Due to the fairly complex cross-section and filleting, the total machining time for all the rods was about 20 hours. The spindle speed using my Tormach Speeder was 13k rpm, and this allowed me to use feed-rates up to 25 ipm. Without the Speeder the machining time would have been close to 60 hours, and I likely would have opted to greatly simplify and (maybe) compromise) the rod design.
It's with this part that the enormity of this project has struck me. It's one thing to need 20-40 pieces of something requiring 10 or 15 minutes of machining time each but quite another when the required machining time for each part is an hour or more.
After the parts were free of their workpieces I made a simple fixture to support them while oil holes were drilled at each end. These holes actually have tapered lead-ins to encourage oil entry and so their sectioned profiles look like tiny funnels.
The resulting offset between the top and bottom finished sides ended up being nearly zero along the y axis but was about .002" along the y axis. I planned on leaving the rods 'as machined' since they are internal to the engine, and the offsets gave them a realistic 'cast' appearance. But, I couldn't leave well enough alone and eventually polished out the offsets as well as the machining marks.
The next step will to be machine the master rods. Fortunately, I need only two of these. - Terry
