I've been anxious to get back into the shop, and so I decided to take a break from the head design and make a 'small' trial run of cylinders. I'm pretty satisfied with the current cylinder design, and after all the time I've spent thinking about them, it's probably safe to find out if I can build them. I decided to make an initial lot of six parts since I was able to round up enough scrap in my shop for that many, and I need at least four cylinders to verify the critical clearances around the oil sump on the bottom of my crankcase. My approach to making a large batch of identical parts is to make a 'prototype' run and to develop a step-by-step process for making them as efficiently as I possibly and then carefully document it. Due to the large number of parts I'll eventually be making I want to have the machines do as much of the finishing as possible in order to minimize manual clean-up. I'll use this process later to make the remainder of the parts and also any replacements I may need in the future.
I started by sawing six identical lengths of 1-3/4" diameter 12L14 rod. These were chucked in my Enco 12x36 lathe where all the heavy cutting was done to prepare them as blanks for my cylinders. The parts were faced to .050" over the cylinder's finished length, and then the centers were drilled out in two steps to 15/16". The OD's were finally turned to .025" over the cylinder's maximum finished OD. The manual preparation time for each of these blanks turned out to be about 45 minutes.
The blanks were then chucked into my 9x20 CNC converted lathe where the bores were completed. I wrote two simple programs to bore the IDs. The first one roughed the ID to 0.986", and the second one finished the bore out at 0.998". The tool offset was corrected to match the actual measured ID of each roughed part before the final finishing program was run. This resulted in all the finished bores being within 0.0002" of each other. I used high rake Korloy inserts designed for aluminum to get a mirror finish even though the cylinders will be honed later. My own personal experience with honing is that trying to remove more than a half thousandth is a long, messy, and, in general, miserable experience with sometimes inconsistent results. Therefore, I try to get the cylinders as close as possible to their finished state before honing. If I can hold the .0002" over my complete run of cylinders, I may lap them instead of honing. My lathe left a 0.0005" taper over the length of the blank, and so I was careful to make sure the small end wound up at the top of the combustion chamber. The important part of the taper which is that seen by the combustion rings is less than half of the total; and nearly all of that will, hopefully, be honed or lapped away later.
I was only able to get four finished bores per insert edge which is pretty extravagant, but the worn inserts still have lots of aluminum roughing time left on them for later projects.
For the remainder of the lathe work the blanks must be supported by their IDs using an expandable mandrel that I turned for this purpose during my H-9 build.
The aluminum heads will eventually be screwed onto the cylinders. The first operation on the mandrel was to prepare the top of the cylinder and to turn the threads, thread relief, and a mating surface for a soft aluminum head gasket.
The tapered body with its fully radiused fins and filleted cooling grooves is a complex feature of my cylinder design, and it has to be carefully machined to avoid a lot of tedious and inconsistent manual clean-up. My plan involved using a full radius grooving tool and a CAM program to fully machine the complex surfaces with negligible scallops. Unfortunately, the grooving operation available in my CAM software didn't seem to like the tapered body of my cylinders. Grooving and parting on my lathe, especially in steel, is always a sobering experience because of the machine's lack of rigidity. Every new project is a new experience requiring lots of experiments and sacrificial inserts to find just the right combination of feeds and speeds that not only just machine the groove but also give a nice surface finish. I generally have to take small bites with aggressive feeds and plenty of chip breaks. Because of the shape of my cylinder, the CAM software wanted to generate tool paths that spent most of the machining time cutting air and using up the chip breaks before plunging the tool into the workpiece the full depth of the groove. Adding insult to injury, the simulator estimated the machining time to well over an hour. I spent some 10 hours convincing it to behave rationally and eventually ended up with a 10 minute operation that did a beautiful job. As is sometimes the case, I had to lie to the software about the shapes of the workpiece and the part and then fiddle, in trial and error fashion, with several of the operation's parameters. If the real truth were known, though, I wouldn't be surprised if most of my problems were caused by my incomplete understanding of the software.
Another grooving program was written to clear out the material above the mounting flange where no other turning tool would fit. This grooving operation was relatively straightforward after my experience with the first one. Two final programs had to be created. One removed OD material from below the mounting flange and the other cut a short ID taper in the bottom of the bore to provide clearance for the connecting rod. This taper will also help ease the insertion of the ringed pistons during assembly.
The final results are shown in the photos. The surface finish is as the parts came off the lathe and will require no polishing before being blued. The only manual clean-up required is the removal of a 'whisker' where the last thread at the top of the cylinder terminates in the thread relief groove. The cylinder clearances around the oil sump were checked, and I also verified that I could actually insert the cylinders into the crankcase bores around the sump with the studs temporarily installed. One of the photos also shows a side-by-side comparison of my twin-18 cylinder with a stock Hodgson cylinder from my H-9 build. All six blanks made it through to good finished parts even though I had expected to ruin a couple along the way.
The machining of these cylinders is an example of a fairly complex project done on hobby-level CNC equipment but which could also have been done manually. I think it's interesting to recall what was required to create the first articles.
Approximately 45 minutes of manual prep was required to create each blank that my CNC lathe could handle. Ten individual g-code programs were created to complete the machining of the cylinder. Seven of these were rather trivial, and were quickly done using the conversational wizards within the Mach-3 control program. The other three required CAM software for their creation. I spent a total of 12 hours creating these programs, but the learning experience with the particularly troublesome grooving program consumed 10 of those hours. The total CNC machining time for all ten programs turned out to be about one hour per cylinder. This included the part set-ups, machine referencing, and verification of the parts. Therefore, amortized over an eventual 24 cylinders, my CAM time per part will be about 1/2 hour. The total fabrication time per cylinder added up to be 1-3/4 hours for a grand total 2-1/4 hours of my actual time per cylinder.
Hodgson estimates 8 hours of machining time by a typical builder for one of his H-9 cylinders, and they are comparable in complexity to my design. That's probably close to the time it would take me to make one assuming I could create a form tool for the fins that my lathe can handle. Unfortunately, though, after the third or fourth cylinder I'd probably set the project up on a high shelf.
- Terry
