Fascinating stuff!
Can you elaborate on your clearance. Is it the same (0.015") amount at the outer diameter ring edge (blue line) as along the curve edge blade profile (red line)?
I just naively assumed gap clearance would have to be very small on something like this, so there is no pressure leak-off betwen individual impeller chambers. Kind of analagous to valve sealing. But I dont have a good grasp of impeller dynamics. Maybe pressure differences are very low to begin with & nothing really happens flow wise until any given inlet valve becomes open, then any adjacent chamber is going to 'feed' it? Is that the general principle?
Peter,
The clearance I'm talking about is between the edge of the impeller blade (the red line in your drawing) and the air guide integral to the rear cover that fits down over this section of the crankcase. If you look back in my earlier post where I was machining the rear cover you'll see a photo showing the interior profile of the rear cover. This profile forms a smooth funnel-shaped volume which guides the air/fuel to the intake ports. I designed the profile of the impeller blades (your red lined ends) to fit up into this funnel profile and to clear it by .015" along the length of most of your red line.
When a valve opens, then the pressure will drop and the 'chamber' over the intake port will feed the valve instead of the entire plenum. This may (hopefully) result in a bit higher velocity in the plenum or it may not. The numbers show that, even with only seven blades, 3-4 chambers will pass by the intake port during a 208 degree intake duration. - Terry
