Man oh man does that look sweet
...After Loctiting the gears to their shafts I trued them in the lathe for 0 run-out. ... I'm creating a fixture that I will use to cross-drill a hole through the gears and their shafts for locking pins.
- Terry
Petertha,So the first loctite application is intended to stick the gear to the shaft with enough retention that you can touch them up on the lathe? What loktite do you use for this?
Re the cross drill & pin business, assume the pin is centered through a tooth 'valley', into the shaft. Do you continue part way into the other side of the gear but dead-ended in the hub part? Will you use tapered pins or straight segment?
Nice pond!
-Peter
2 questions Terry
Re the 4140 cam disc, you mentioned sourcing from oilfield pressure vessel, annealed, sliced, machined, then heat treated @1550F, oil quenched, temper @ 500F 'to restore the hardness of 4140'.
- was the first stage (annealing) because it was originally in some other hardness state from its oilfield purpose?
- ie if you happen to have stock 4140, would it be just slice/machine, then harden?
- out of interest, does this exceed what Hodgson plans call for? Ive seen so many ways of going about this on model engines ranging from nothing to case harden to what looks like cadillac here
Re the bronze bushing slug technique again, what is your recipie in terms of OD/ID fit & locktite PN? Any recipie difference between aluminum vs steel as the parent metal? Ive always been scratching my head how thin wall bushings could be pressed into connecting rods & such without distorting, but I now I know better - a better technique with a slug.
Real good info, thanks. Your material usage caught my eye because I have a feeling there may be similar resources of suitable metal cut-offs via scrap/salvage shops in my (oily) neck of the woods. I'm not in that line of work per se but I have seen 4140 for example as being pretty common. But real important point noted - all depends on where it originated from &any previous heat treatment.
So what Locktite flavour would you typically use for bronze slug inside aluminum parent material & same question if steel parent? How about primers or whatever they call prep agents for certain Locktite PN's?
