Another Internal Combustion Engine
Weirsdale, Florida
I know the title is kind of vague but I really haven't made up my mind yet. I was thinking of a side shaft Hit Miss engine, or an overhead cam Hit miss engine , or a marriage of the two so I will just start and see what happens.
I haven't had a lot of shop time with 2 hurricanes and the cleanup afterwards. The tractor fan blade went through the radiator so I had to replace that and the wife keeps finding new projects for me to do but I'm going to start this anyway.
I have had these two weights around for some time and they are of no use like they are so why not make a couple of flywheels.
Now I have had good luck machining weights in the past to make flywheels but this time the outer part of the rim was very hard. Carbide inserts would just throw sparks and then give up. The sides machined OK but the rim was made from ???
I had to resort to the tool post grinder for a decent finish on the rim.
And the finished product. Two 5" flywheels with taper lock hubs.
It's a start.
Thanks for looking
Ray
I had started this crankshaft a couple of days ago. It has a 3" stroke.
It is assembled on a 12mm shaft with a loose fit and Loc-Tite 620. I used the lathe to hold everything in line over night.
This is after I installed tapered pins and cut out the middle section of the rod.
The shiny places are where I filed the pins smooth.
And painted and done.
Thanks for looking
Ray
Thanks for looking
Ray
I've got a whole bunch of those weights that have flywheels inside.
Richard it seems to be a hit miss if you get one that will mill half way decent these were not good.
This aluminum is what is left over from my 6 cyl build.
It was too large in all dims so over to the band saw.
First a 1 1/2" wide slice over the width.
Then two cuts to remove the angled piece.
The setup looks dodgy but it worked just fine.
Right off the band saw.
And after truing up all sides.
Thanks for looking
Ray
I wonder if those weights are spin cast. That might cause some migration of heavier elements to the outside during the pour. Probably a lot of nickel in the rim of those castings.
I don't know but it sure was hard to machine.
I made a bunch of chips and I got rid of anything that didn't look like an engine base.
No end mills were harmed in this operation.
I really like the idea of a one piece engine base.
I may use this style more often.
I also cut out and installed the two main bearing caps.
Thanks for looking
Ray
Drilling the holes for the main bearings.
And finishing to size with a boring head.
I made a brass spacer to go between the bearing race and the crankshaft on each side to lock the crank in place.
(Sorry but you can't see them in this Picture)
(No not this picture either)
Maybe I shouldn't have mentioned them.
Thanks for looking
Ray
You make this look way too easy ! I can't believe how fast you build a engine and how nice the end results are.
Probably not spin cast, just the cheapest quickest sand casting they can do (gym weights just need to be heavy) If they used chills in the moulds the rims would be cooled quick enough to turn into white iron, which is very hard.
Be easy to anneal them if you have a fireplace.
