Hi Rich,
Looking good so far...... I would assemble the end plates, stays and end bushes first (all as one assembly)... fit the stays with the mushroom heads at the same end as the bushes....apply plenty of flux as you assemble, making sure the end plates are aligned properly..... stand the boiler on some supports which will allow the plain ends of the stays to remain clear of the hearth...... solder the first end around its rim (keep the flame more on the barrel whilst doing this joint, to ensure correct penetration of the solder), and then work your way in towards the stays, soldering the bushes as you come to them..... finally solder the stays.....you can add more flux as you go, should it be necessary.
Allow to cool,enough to handle...turn over and support on the soldered end..... check the second end joints for flux, add more if necessary, and then solder this end...rim first, followed by the stays.
Drop the whole thing in the pickle for a couple of hours, when it has cooled enough to easily handle.
I would next do the studs...... assemble/insert them all at the same time, fluxing as you go and then gently heat up as a whole...this will solidify the flux (boils off the water) then you can concentrate on soldering each row at a time.... keep the flame more towards the barrel, since this will take most of the heat....the studs will heat up more by conduction.
TIP... if you can source some 0.8mm dia or 1mm dia easy-flo silver solder wire (Blackgates engineering stock it) you can make the job of soldering the studs a bit easier by making small rings of solder with the same ID as the OD of the studs.... slip one over each stud after you have insert it into the shell and fluxed it...push it gently down into the flux, up against the barrel..... these will melt and flow when the correct temperature has been reached...... saves a lot of time and gives less chance of unwanted excess solder running around the barrel.
Finally (after cooling down enough) turn the boiler over, and give the areas around the dome and safety valve bush a good scrub with some oil free steel wool, or med wet and dry, and fit the dome and safety valve bush with plenty of flux..... gently heat up again keeping the torch moving over the outer shell then concentrate the flame more around the bush, followed by the dome...... Allow to cool...drop the whole thing in the pickle and have a beer....you have a boiler.
Small drill are best run as fast as you can...and a peck drilling action (to clear the swarf (chips)) will be best.
Keep happy.
sandyC  ;D ;D ;D
