;D
Hi again,
FB.....Citric acid pickle should really be made up by disolving as much as possible into a given volume of water, i.e. saturated solution, this helps a great deal in minimising/eliminating bacterial growth...the normal cause of slimey growth.
I use it myself for most small jobs (I use sulphuric for larger boilers) and find it lasts for months without any degredation from such growths.
You can add a very small capful of domestic bleach, when you make up a new brew...and contrary to the opinion that adding an alkaline substance to an acid (the argument states it ruins the pickle) I have found it does prevent any bacterial growth..... and the very small amount of bleach does not make very much difference to the overall acidity.
Copper and bronze will generally remain in an annealed state (they do gradually return to half hard but over a very long time), the down side is...they are very much more prone to surface damage whilst in this state....I would normally just anneal when required.
Another good hearth material, and very cheap to buy, is thermalit building blocks (obtainable from any good builders merchants) they measure approx 18" x 9" x 4" and are quite soft and easily cut with an old panel saw and half a dozen can form a very good hearth.
My own hearth is made/lined with these and I also have a few broken up ones to pack around items to retain the heat. The last ones I puchased, about a year ago, were less than £1.00 each...very much cheaper than refractory blocks.
Brian, welcome to the mad house.....
Yes you are quite correct and I would not anticipate, or encourage this practice on a high pressure boiler.
The marks applied in this case can, and will, be polished out during the cleaning process prior to silver soldering.
The hoop stress calculations for this boiler shell returned a max safe working pressure of around 96psig allowing a safety factor of 8 and as it will only be used at around one third of this (35psig) there is an added safety factor within the design.
Having said this, deep score marks can, and do, create serious problems so thanks for bringing the point up, as it can very easily be overlooked.
Keep happy guy's.
Best regards,
SandyC
;D ;D
