;D
Hi Firebird,
You are on the right track with the added pre-heater. As you say, a marked improvement.
Might I suggest, if you are going to build a new burner, to make the jet holes smaller (say No 76 (0.5mm) or even No 80 (0.35mm) dia) and use more of them....say 18.
Also, if you can keep the wall thickness of the mushroom sections down to around 0.020" (0.508mm)then I think you will get a better evaporation of the Meths and a better flame pattern.
You may also find that you can reduce the pre-heat flame level a good bit....i.e.shorten the exposed wick, this will have the advantage of lower overall fuel consumption.
If you look at the version you are trying to emulate, you will see that he has a large number of smaller holes on his burner.
The overall plan for your new, two headed, burner looks good and should work well, possibly with the above additions included....the only thing you will need to be carefull of is that the Meths level in the main tank should not be higher than approx one third - half way up the pre-heater tube, otherwise you may find the meths expands to much in the pre-heater feed tube and will overflow....not good.
I am sure you will eventually find the correct combination.
Returning to your boiler...... I would suggest that you mark a vertical centre line on your end plates (if you have the vee attachment for your combination square you can use this to find the centre of the disk) and then take one end of the mark round the flange (make this the top) and make a good heavy mark on the flange bend.
If you also (using your combination) mark the top centre of the barrel, on the edges, again make good heavy marks, then you can easily line up the end plates with these marks when you fit them.
This will be important, since you need to keep the STAY holes aligned at both ends of the boiler...or you will have a lot of trouble fitting the stays.
If you don't have the vee fitting for your combination, then you can use the same method as for finding the centre...i.e. put it on the lathe...but use a sharp lathe tool to scribe a line across the plate.
Extend this round the flange edge using a scriber, or a stanley knife blade.
To mark the barrel....fit one end plate (just pushed in) and mark one end of the barrel in line with the flange mark.
Place the barrel on a pair of vee blocks with this mark roughly in the horizontal position and lightly clamp it so that it cannot move.
Set a height gauge (or scribing block) to the height of the mark and lightly scribe along the outside of the barrel and round the opposite end.
Enlarge the end marks with a stanley knife blade so that they are easily seen and dont get rubbed off when you come to clean the copper for soldering.
The line marked on the outside of the barrel will become the top centre line along which you can mark the positions for your Dome (if fitted) and safety valve bushes.
Hope this is clear and helps a bit.
Keep up the stirling work.
Best regards.
SandyC ;D
