Chuck,chuck foster said:correct me if i'm wronge but i think if you were to get oil in the boiler it would cause the water to foam ???
chuck
The oil will coat the inside of the boiler preventing the water from conducting the heat away causing a hot spot that could fail. The water in a boiler is actually cooling the shell by absorbing the heat. It only takes a thin film of oil.
We used several methods of removing oil from the water on the tanker I sailed on. Lube oil from the turbines would seep into the steam and had to be removed before heading back to the boilers.
