Hi Andy
Brass rod is not the same as bronze, even though they look the same. Brass is mostly made of an alloy of copper and zinc, while bronze is an alloy of copper and tin. Both can have some additional elements added to make different varieties of each.
Use of brass is discouraged for boiler bushings, as the zinc in it will leach out over time, making joints brittle, that's why bronze is the preferred metal for bushings and so on.
When looking for bronze for bushings, make sure to steer clear of aluminium bronze - it contains some aluminium and can be problematic to solder/braze. Phosphor Bronze works a treat though Thm:
Regards, Arnold
