Hi
The boiler case wasn't quite flat on its top and bottom edges so I mounted it in the mill and skimmed a few thou of both faces.
Sandy made a suggestion about a firehole door.
I do like your solution to the variable air vents, now you need to consider fitting a firehole door which will help them perform more accurately by ensuring that combustion air is drawn through them rather than via the firehole.
Something else to think about!!!.
Well.............................OK................ go on then.
I started on the doors by making the hinges first. While figuring out how to make the hinges it suddnely came to me why not use readily available brass door hinges.
Knock the pin out.
Screw the halves to a scrap of wood and chop off the bits in the bandsaw.
I had to make a little jig to hold them so I could machine them all to size.
Two pieces of 3 mm ally plate held together in the mill and machined to size.
Then held side by side in the mill. Wheel bearings used as spacers and drilled out with a step drill.
Drill 1/16 holes in the hinges and the doors.
And then rivet them to the doors.
I countersunk the holes on the back of the doors so the rivets would lie flush.
Mount the other half of the brass hinge in the mill and machine out.
Once they have been cut out all the hinge pin holes were drilled out to 3/32. I have some 3/32 stainless steel to use for the pins. Slide some 3/32 through the hinges and clamp the door and hinges in the mill and drill out to accept 5BA.
Make some 5BA pins from stainless steel.
The hinge pins are 3/32 stainless steel with a small 1/8 stainless steel cap pressed on one end.
The pins just push in from the top.
They need to be polished up now to finish them off
A bit of video.
Rich
